NXC "File Error!"
jld001
NXC "File Error!"
Post by jld001 »
task main() {
int select=10, board[9], i;
for (i=0; i<9; i++)
    board[i]=0;
PlayTone(500,500);
Wait(1000);
for (i=9; i>0; i--) { if (board[i]==0) {PlayTone(1000,500);Wait(1000);} } //ERROR HERE(?)
PlayTone(2000,500);
Wait(1000);
Will someone try out this NXC code? My NXT with 1.31 Enhanced Firmware is says "File Error! -1"
On the standard NXT firmware it just says "File Error!"
I think that the issue is something to do with arrays. Any ideas? Thanks!
My Githubz of Source Codez, in order of awesomeness:
https://github.com/ArtskydJ/NXC_Source
https://github.com/ArtskydJ/NXC_Tests
My Lego Creations, in no particular order:
LEGO Bop-It - http://www.youtube.com/watch?v=6TsqrBVKbj0
LEGO Safe - http://www.youtube.com/watch?v=MyDRfVquHuY
Re: NXC "File Error!"
You are trying to access board[9] (tenth element), when you declared it with only 9 elements (numbered 0-8). The second for loop repeats 9 times, with variable i's value starting at 9 and going down to 1 (when i gets to 0, it breaks to the end of the for loop).
I think this is what you want:
task main() {
  for (i=0; i<9; i++)
    board[i]=0;
  PlayTone(500,500);
  Wait(1000);
  for (i=8; i>(-1); i--){
    if(board[i] == 0){
      PlayTone(1000,500);
      Wait(1000);
  PlayTone(2000,500);
  Wait(1000);
With this code, the value of i in the second for loop starts at 8 and goes down to 0. When it becomes -1, the program jumps to the end of the for loop.
In NXC, trying to access an element beyond what has been declared will crash the program (and IIRC, with "File Error! -1").
jld001
Post by jld001 »
Thanks, those off-by-one errors are annoying.
Users browsing this forum: Semrush [Bot] and 21 guests
