Modulo Block for NXT version 2.0
gavilanp
Post by gavilanp »
With floating point math in the NXT software, it's no longer possible to compute modulo (no complaint about floating point ;) ).
Is there any available option for it, or an integer block which could then be used in a myblock to compute modulo.
thanks.
Re: Modulo Block for NXT version 2.0
Don't know of any custom blocks, but I think all you have to do is carry out the division then subtract the original number to get the decimal bit.
Post by hassenplug »
You may want to look into how to install the integer blocks.
http://www.teamhassenplug.org/NXT/NXTGAdditions.html
gavilanp
Post by gavilanp »
Steve, i put the integer math block on the palette and now i can compute modulo.
Thanks for pointing that to me, somehow I missed that although I had visited that page in my original search.
