Accessing libfantom.so from Python (pyfantom) in Linux
tcwan
Post by tcwan »
Hi John,
I've remember your interest in pyfantom for Linux, I've updated pyfantom to be able to run on Linux and Windows, though it has not been tested at all.
http://pyfantom.ni.fr.eu.org/
I've compiled libfantom.so and related utilities with debugging enabled on 64-bit Fedora 17 from BricxCC SVN Rev. 623. spirittest can access the NXT correctly.
$ spirittest -listbricks
0016531A1E5D=USB0::0X0694::0X0002::0016531A1E5D::RAW
However, when I tried using pyfantom to access the libfantom.so library using the Python ctypes interface, it is crashing badly.
$ gdb python pyfantom.py
GNU gdb (GDB) Fedora (7.4.50.20120120-50.fc17)
Copyright (C) 2012 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-redhat-linux-gnu".
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>...
Reading symbols from /usr/bin/python...(no debugging symbols found)...done.
"/home/rpmbuilder/rpmbuild/BUILD/pyfantom/pyfantom.py" is not a core dump: File format not recognized
Missing separate debuginfos, use: debuginfo-install python-2.7.3-7.2.fc17.x86_64
(gdb) run pyfantom.py
Starting program: /usr/bin/python pyfantom.py
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
Detaching after fork from child process 1667.
Running on Linux Platform
Detaching after fork from child process 1669.
Detaching after fork from child process 1671.
Detaching after fork from child process 1675.
Detaching after fork from child process 1677.
Found Fantom Library ( libfantom.so )
Load Library Done
Retrieving list of NXT objects
warning: Range for type <error type> has invalid bounds 0..-121
Program received signal SIGSEGV, Segmentation fault.
GETNXT (this=0xf7fe4160, STATUS=8294160) at bricktools/fantomfpc.pas:3283
3283	  if fNXTViaUSB then
(gdb) bt
#0  GETNXT (this=0xf7fe4160, STATUS=8294160) at bricktools/fantomfpc.pas:3283
#1  0x00007fffefb8d9e6 in NFANTOM100_INXTITERATOR_GETNXT (
    NXTITERHANDLE=4160635232, STATUS=0) at bricktools/fantomfpc.pas:838
#2  0x00000038f9e05e90 in ffi_call_unix64 () from /lib64/libffi.so.5
#3  0x00000038f9e058a0 in ffi_call () from /lib64/libffi.so.5
#4  0x00007ffff18a9bd0 in _ctypes_callproc ()
   from /usr/lib64/python2.7/lib-dynload/_ctypes.so
#5  0x00007ffff18a33dd in ?? ()
#6  0x000000390da49a7e in PyObject_Call () from /lib64/libpython2.7.so.1.0
#7  0x000000390dad93e3 in PyEval_EvalFrameEx () from /lib64/libpython2.7.so.1.0
#8  0x000000390dadcd51 in PyEval_EvalFrameEx () from /lib64/libpython2.7.so.1.0
#9  0x000000390dadcd51 in PyEval_EvalFrameEx () from /lib64/libpython2.7.so.1.0
#10 0x000000390daddb1f in PyEval_EvalCodeEx () from /lib64/libpython2.7.so.1.0
#11 0x000000390daddbf2 in PyEval_EvalCode () from /lib64/libpython2.7.so.1.0
#12 0x000000390daf6b9a in ?? () from /lib64/libpython2.7.so.1.0
#13 0x000000390daf7992 in PyRun_FileExFlags () from /lib64/libpython2.7.so.1.0
#14 0x000000390daf83ab in PyRun_SimpleFileExFlags ()
#15 0x000000390db09882 in Py_Main () from /lib64/libpython2.7.so.1.0
#16 0x00000038f7621735 in __libc_start_main () from /lib64/libc.so.6
#17 0x00000000004006f1 in _start ()
(gdb) list
3278	function TNxtIterator.getNXT(var status: integer): TNxt;
3279	begin
3280	  Result := nil;
3281	  if status < kStatusNoError then Exit;
3282	  Result := TNxt.Create;
3284	  begin
3285	    Result.fPort := GetUSBResString(fDev, fDevHandle);
3286	    Result.fCheckver := False;
3287	    Result.fDev := fDev;
(gdb) print Result
$1 = (^TNXT = class ) 0x7ffff7ff4180
(gdb) print fNXTViaUSB
Cannot access memory at address 0xf7fe418c
(gdb)
It crashes when trying to access a global variable fNXTViaUSB. I'm not sure if this is due to any differences between Pascal generated libraries and C generated libraries or not. Is there anyone have experience with multi-language object code who can comment on this issue?
bricxcc-svn-build.tgz
SPEC file and patches to build BricxCC SVN on 64-bit Fedora 17
(3.87 KiB) Downloaded 633 times
Re: Accessing libfantom.so from Python (pyfantom) in Linux
I will run some tests this week to see if I can figure out what might be going wrong. Can you send me the python code that you used to call into my libfantom.so library?
John
tcwan
Post by tcwan »
It's accessible from the URL I posted previously http://pyfantom.ni.fr.eu.org/, but since it is tiny, I'm adding it as an attachment to this post.
pyfantom-20120927.tgz
TGZ for pyfantom python script
(25.87 KiB) Downloaded 646 times
