Dexter NXTChuck
bmancan
Dexter NXTChuck
Post by bmancan »
Check out the new device from Dexter Industries that allows for connection between the NXT and the Wii Nunchuck controller.
http://dexterindustries.com/blog/2012/1 ... torms-nxt/
The announcement also gives credit to mattallen37 for his collaboration on the design and programming.
Way to go Matt!
BManCan
Re: Dexter NXTChuck
credits also due to tom123 who already published this in our German forum in 2008:
http://www.mindstormsforum.de/viewtopic ... uck#p32164
AND sebi who published this in our German forum in 2010:
http://www.mindstormsforum.de/viewtopic ... 252#p51252
Re: Dexter NXTChuck
Thanks BManCan!
@ Helmut, the design isn't based on any one design or idea. The actual function is quite a different approach to any projects I had seen, making it unnecessary to do any HW modifications to the Nunchuk. Even if the design wasn't unique, it is now, now that it is actually a finished product.
hergipotter
Re: Dexter NXTChuck
Post by hergipotter »
May I ask whats on the NXTChuck PCB? I guess only the pull-up resistors and a voltage level converter?
So practically I could use your NXTChuck lib with my modded Nunchuk and WM+? :D Your code is much better written than mine ;)
Re: Dexter NXTChuck
Pullup resistors and voltage and signal level converters, basically.
Yes, you should be able to.
Re: Dexter NXTChuck
tom123 » 16. Nov 2008, 20:32 wrote:für den Stecker-Adapter sehe ich mehrere Möglichkeiten:
Variante 1:
Du kannt vier dicke Drähte auch Lochraster löten und hast einen halbwegs stabilen Stecker. Ich hatte den Stecker in ein Steckbrett gesteckt:
Variante 2:
ein kommerzieller Adapter von http://store.fungizmos.com/index.php?ma ... cts_id=212
Variante 3:
...nimm einen I2C-Portadapter:
http://focus.ti.com/lit/ds/symlink/p82b96.pdf
alternativ die den Pegelwandler aus einer Philips Application note.
http://www.nxp.com/acrobat_download/app ... 0441_1.pdf
Rp auf der linken Seite sind schon da / Rp rechts = 82k Lego
Re: Dexter NXTChuck
What are you trying to communicate, or are you just trolling?
If you are trying to state the obvious, in that my design isn't groundbreaking technology, it is already, as I said, quite obvious.
I said that the function is different from any approach I had seen (past tense). And as of writing this, I still have yet to see another project that is the same as mine.
Please only write constructive posts on these forums.
Re: Dexter NXTChuck
just constructive alternative options to the Dexter Nxtchuck
bmancan
Re: Dexter NXTChuck
Post by bmancan »
mattallen37 wrote:What are you trying to communicate, or are you just trolling?
Matt,
I think that some people have trouble seeing others get recognition for their efforts. Typically just simple jealousy. Congratulations on your NXTChuck contribution, it is nice to see fellow Mindstorms fans have their work recognized.
Keep up the good work!
BManCan
Re: Dexter NXTChuck
I - jealousy?
no, not at all. Own hardware development was never ever my intention. It was actually tom123, sebi, Legorentner, and others who once made and published those former alternative developments publicly - Open Source - several years ago to our community, their performance was also remarkable, they and their work also should not be forgotten.
I was not envolved in that at all in any way.
I respect people who have commercial success, but I admire people who share their knowledge and efforts with a community for free, like the ones mentioned above, and like Linus Torvalds for his LINUX, and Jimmy Wales for his Wikipedia - and last, but not least, John Hansen for his NXC.
Probably this is the point which I actually tried to communicate.
