NXC: RemoteStopProgram doesn't compile
I try to use RemoteStopProgram(CONN_BT1) but it doesn't compile.
I only get "Error: Unknown or invalid statement".
RemoteStartProgram(CONN_BT1, "filename.rxe") works fine.
I use BrixCC v3.3.
I use BrixCC v3.3.
Re: NXC: RemoteStopProgram doesn't compile
The following worked for me:
I am using BricxCC 3.3.8.10
RemoteStartProgram(CONN_BT1, "filename.rxe");
RemoteStopProgram(CONN_BT1);
McSummation aka James
Weird. Doesn't work.
I have build 3.3.8.9 which seems to be the latest here:
http://sourceforge.net/projects/bricxcc/files/bricxcc/
nbc v1.2.1.r4.
nbc v1.2.1.r4.
http://www.mindstormsforum.de/viewtopic.php?f=25&t=3311
(1) Uninstall all old BCC versions
(2) install latest Bricxcc:
https://sourceforge.net/projects/bricxcc/files/bricxcc/
(3) Install BricxCC Bugfix Update:
http://bricxcc.sourceforge.net/test_releases/ (extract + copy into BCC folder),
upload the fw contained on to your NXT
Download the latest test release (as of writing this, it's 20121101, and can be downloaded from here) and install it over the current installation. That will update BCC to the latest available version. I also suggest you update your NXT's FW to the FW that's included in the test release.
In regard to Helmut's post, I must disagree. You already have the latest official release of BCC installed, so it's just a matter of installing the test release over it.
In regard to matt's post, I must disagree. It was sort of general quick guide.
Installing the test release solved it. Thanks.
