Hidden Advanced features of NXTG
creator1
Post by creator1 »
for windows user, under the profile folder, setting.ini
search for
Enable Advanced Features=FALSE
change to
Enable Advanced Features=TRUE
then, more datatype will be available: logic array, number array, integer array, text array
what are these for ?
Re: Hidden Advanced features of NXTG
Tried it on NXT-G 2.0 but couldn't see any new data types.
Did find this on http://forums.usfirst.org/showthread.php?p=59832
Originally Posted by Dean Hystad View Post
One thing you may find beneficial is enabling advanced features. Go to the directory for the profile you are using. It will be something like :
C:\Users\***\LEGO Creations\MINDSTORMS Projects\Profiles\Default
In that directory there is a file named "settings.ini". In the file there is a line:
Change the "FALSE" to a "TRUE" to enable advanced features.
The only useful "Advanced Feature" I've found is enhanced editing for wiring. With advanced features turned on you can see the connection point where wires pass into/out of switches and loops. It also highlights wire segments when they are selected in the editor.
Post by hassenplug »
There are a few cool tools at the bottom of this page: http://www.teamhassenplug.org/NXT/NXTGAdditions.html
In addition to showing user settings, there's a "remove bad wires" function.
I managed to install the 'remove bad wires' function while I was using NXT-G (before moving to BCC).
Out of interest, I have just tried installing the 'User settings' one but got lost very quickly.
Where exactly should I put the file (no, don't say it!) and just what does it do anyway?
