who already owns a Intel Galileo Board ?
hi,
not already quite Mindstorms yet .... not yet.... 8-)
any member in this forum who already owns a Intel Galileo Board ?
http://www.aliexpress.com/item/Intel-Ga ... 94699.html
http://www.cooking-hacks.com/documentat ... les-boards
if anyone is around:
As the Galileo is Arduino-software compatible:
could you please test this following Arduino Sketch benchmark code on the Galileo and please report the results?
No code changes should be necessary!
// hw brickbench
// benchmark test for NXT/EV3 and similar Micro Controllers
// PL: Sketch 1.5.6-r2
// platform: Arduino (u.a. Mega 2560, Due)
// Autor: (C) Helmut Wunder 2013, 2014
// freie Verwendung für private Zwecke
// für kommerzielle Zwecke nur nach Genehmigung durch den Autor.
// protected under the friendly Creative Commons Attribution-NonCommercial-ShareAlike 3.0 Unported License
// http: //creativecommons.org/licenses/by-nc-sa/3.0/ //
// version 1.08.0004
#define TimerMS() millis()
unsigned long runtime[8];
int a[500], b[500], c[500], t[500];
// Mersenne Twister
unsigned long randM(void) {
   const int M = 7;
   const unsigned long A[2] = { 0, 0x8ebfd028 };
   static unsigned long y[25];
   static int index = 25+1;
   if (index >= 25) {
     int k;
     if (index > 25) {
        unsigned long r = 9, s = 3402;
        for (k=0 ; k<25 ; ++k) {
          r = 509845221 * r + 3;
          s *= s + 1;
          y[k] = s + (r >> 10);
     for (k=0 ; k<25-M ; ++k)
        y[k] = y[k+M] ^ (y[k] >> 1) ^ A[y[k] & 1];
     for (; k<25 ; ++k)
        y[k] = y[k+(M-25)] ^ (y[k] >> 1) ^ A[y[k] & 1];
     index = 0;
   unsigned long e = y[index++];
   e ^= (e << 7) & 0x2b5b2500;
   e ^= (e << 15) & 0xdb8b0000;
   e ^= (e >> 16);
   return e;
// Matrix Algebra
// matrix * matrix multiplication (matrix product)
 void MatrixMatrixMult(int N, int M, int K, float *A, float *B, float *C) {
   int i, j, s;
   for (i = 0; i < N; ++i) {
      for (j = 0; j < K; ++j) {
         C[i*K+j] = 0;
         for (s = 0; s < M; ++s) {
            C[i*K+j] = C[i*K+j] + A[i*N+s] * B[s*M+j];
// matrix determinant
float MatrixDet(int N, float A[]) {
   int i, j, i_count, j_count, count = 0;
   float Asub[N - 1][N - 1], det = 0;
   if (N == 1)
      return *A;
   if (N == 2)
      return ((*A) * (*(A+1+1*N)) - (*(A+1*N)) * (*(A+1)));
   for (count = 0; count < N; count++) {
      i_count = 0;
      for (i = 1; i < N; i++) {
         j_count = 0;
         for (j = 0; j < N; j++) {
            if (j == count)
               continue;
            Asub[i_count][j_count] = *(A+i+j*N);
            j_count++;
         i_count++;
      det += pow(-1, count) * A[0+count*N] * MatrixDet(N - 1, &Asub[0][0]);
   return det;
// shell sort
void shellsort(int size, int* A)
  int i, j, increment;
  int temp;
  increment = size / 2;
  while (increment > 0) {
    for (i = increment; i < size; i++) {
      j = i;
      temp = A[i];
      while ((j >= increment) && (A[j-increment] > temp)) {
        A[j] = A[j - increment];
        j = j - increment;
      A[j] = temp;
    if (increment == 2)
       increment = 1;
       increment = (unsigned int) (increment / 2.2);
// gnu quick sort
// (0ptional)
int compare_int (const int *a, const int *b)
  int  temp = *a - *b;
  if (temp > 0)          return  1;
  else if (temp < 0)     return -1;
  else                   return  0;
// gnu qsort:
// void qsort (void *a , size_a count, size_a size, compare_function)
// gnu qsort call for a[500] array of int:
// qsort (a , 500, sizeof(a), compare_int)
// benchmark test procedures
int test_Int_Add() {
   int i=1, j=11, k=112, l=1111, m=11111, n=-1, o=-11, p=-111, q=-1112, r=-11111;
   int x;
   volatile long s=0;
   for(x=0;x<10000;++x) {
     s+=i; s+=j; s+=k; s+=l; s+=m; s+=n; s+=o; s+=p; s+=q; s+=r;
   return s;
long test_Int_Mult() {
  int x,y;
  volatile long s;
  for(y=0;y<2000;++y) {
    s=1;
    for(x=1;x<=13;++x) { s*=x;}
    for(x=13;x>0;--x) { s/=x;}
  return s;
#define PI  M_PI
float test_float_math() {
  volatile float s=PI;
  int y;
  for(y=0;y<5000;++y) {
     s*=sqrt(s);
     s=sin(s);
     s*=cos(10.5*s);
     s=sqrt(s);
     s=exp(s);
  return s;
long test_rand_MT(){
  volatile unsigned long s;
  int y;
     s=randM()%10001;
  return s;
float test_matrix_math() {
  int x;
  float A[2][2], B[2][2], C[2][2];
  float S[3][3], T[3][3];
  unsigned long s;
  for(x=0;x<250;++x) {
    A[0][0]=1;   A[0][1]=3;
    A[1][0]=2;   A[1][1]=4;
    B[0][0]=10;  B[0][1]=30;
    B[1][0]=20;  B[1][1]=40;
    MatrixMatrixMult(2, 2, 2, A[0], B[0], C[0]); // <<<<<<<<<<<<<<<<<<<
    MatrixDet(2, A[0]);                          // <<<<<<<<<<<<<<<<<<<
    S[0][0]=1;   S[0][1]=4;  S[0][2]=7;
    S[1][0]=2;   S[1][1]=5;  S[1][2]=8;
    S[2][0]=3;   S[2][1]=6;  S[2][2]=9;
    MatrixDet(3, S[0]);                          // <<<<<<<<<<<<<<<<<<<
  s=(S[0][0]*S[1][1]*S[2][2]);
  return s;
// for array copy using void *memcpy(void *dest, const void *src, size_t n);
long test_Sort(){
  unsigned long s;
  int y, i;
  int t[500];
  for(y=0;y<30;++y) {
    memcpy(t, a, sizeof(a));
    shellsort(500, t);
    memcpy(t, a, sizeof(b));
    shellsort(500, t);
    memcpy(t, a, sizeof(c));
    shellsort(500, t);
  return y;
inline void displayValues() {
  char buf[120];
    sprintf (buf, "%3d %4d  int_Add",    0, runtime[0]); Serial.println( buf);
    sprintf (buf, "%3d %4d  int_Mult",   1, runtime[1]); Serial.println( buf);
    sprintf (buf, "%3d %4d  float_op",   2, runtime[2]); Serial.println( buf);
    sprintf (buf, "%3d %4d  randomize",  3, runtime[3]); Serial.println( buf);
    sprintf (buf, "%3d %4d  matrx_algb", 4, runtime[4]); Serial.println( buf);
    sprintf (buf, "%3d %4d  arr_sort",   5, runtime[5]); Serial.println( buf);
int test(){
  unsigned long time0, x, y;
  float s;
  char  buf[120];
  int   i;
  for(y=0;y<500;++y) {
    a[y]=randM()%30000; b[y]=randM()%30000; c[y]=randM()%30000;
  // LcdClearDisplay();
  time0= TimerMS();;
  s=test_Int_Add();
  runtime[0]=TimerMS()-time0;
  time0=TimerMS();
  s=test_Int_Mult();
  runtime[1]=TimerMS()-time0;
  time0=TimerMS();
  s=test_float_math();
  runtime[2]=TimerMS()-time0;
  time0=TimerMS();
  s=test_rand_MT();
  runtime[3]=TimerMS()-time0;
  time0=TimerMS();
  s=test_matrix_math();
  runtime[4]=TimerMS()-time0;
  time0=TimerMS();
  s=test_Sort();
  runtime[5]=TimerMS()-time0;
  // lcd display text / graphs  not performed!
  runtime[6]=0;
  runtime[7]=0;
  Serial.println();
  y = 0;
  for (x = 0; x < 8; ++x) {
      y += runtime[x];
  sprintf (buf, "gesamt ms: %u ", y);           Serial.println( buf);
  sprintf (buf, "benchmark: %u ", 50000000/y ); Serial.println( buf);
  return 1;
void setup() {
  // put your setup code here, to run once:
  Serial.begin(9600);
void loop() {
   char  buf[120];
  // put your main code here, to run repeatedly:
  test();
  sprintf (buf, "Ende HaWe brickbench");           Serial.println( buf);
  while(1);
Stryker295
Re: who already owns a Intel Galileo Board ?
Post by Stryker295 »
This actually looks really awesome! Wish I could help.
—Jag
Users browsing this forum: Bing [Bot] and 6 guests
