NXC: NXT 2.0 color sensor in lamp mode
Hi.
I'm wondering if anyone knows how to turn on the light on the nxt 2.0 color sensor (not the HT sensor) in NXC?
Tim
Tim
Re: NXC: NXT 2.0 color sensor in lamp mode
I use the following to select mode, and therefore setting the LED control.
SetSensorColorRed(S1); //Turn on Red
SetSensorColorGreen(S1);//Turn on Green
SetSensorColorBlue(S1); //Turn on Blue
SetSensorColorFull(S1); //Turn on all (multiplexed, so not at the same time, thus reducing brightness)Matt
Thanks. I just didn't know that that did it
Thanks again
Tim.
Thanks again
Tim.
How do you turn them off?
Thanks
Tim
Thanks
Tim
NP. I can only assume, but try using the following to turn it off.
SetSensorColorNone(S1);Matt
Thanks.
Does anyone know why the calls SetSensorColorFull( colorSensorPort ) and SetSensorColorNone( colorSensorPort ) each take about 170 milliseconds? It seems like a lot of time just to turn a light on and off. I didn't find any waits in the generated code so I assume that this happens in the firmware.
This is a firmware/hardware thing and a known issue with this sensor.
You call it an "issue", is it messed up (not how it should be)? what is responsible for the delay? Is it the NXT firmware? the sensor? both? I don't like the delay, but if it is an NXT problem, could it be used that much faster with a u-processor as an NXT co-processor (Arduino, or PICAXE)?mightor wrote:This is a firmware/hardware thing and a known issue with this sensor.
I have no idea tbh. One way you could find out is to compare the time it takes with various firmwares
Use an NXT 1.0 light sensor to measure, it's got a 3ms update time.
