BricxCC Ultrasonic Sensor Problem
pesso
Post by pesso »
I am using code (diagram 1.0) for solving a maze. Here is a PDL of what I'm doing:
1) Check US Sensor
2) Move Motor
3) Check US Sensor
4) Move Motor
5) Check US Sensor
6) Move Motor Back To Starting Position
7) Display Values
The motor move fine, but on the NXT's screen, it says "0", "0", and "0"; :!: :?:
The US Sensor is connected correctly into port 4.
      int distance1;
      int distance2;
      int distance3;
      bool object_forward;
      bool object_left;
      bool object_right;
      distance1=SensorUS(S4); // Forward
      RotateMotor(OUT_A, 75, 90);
      distance2=SensorUS(S4); // Right
      RotateMotor(OUT_A, -75, 180);
      distance3=SensorUS(S4); // Left
      TextOut(0, 0, NumToStr(distance1));
      TextOut(0, 8, NumToStr(distance2));
      TextOut(0, 16, NumToStr(distance3));
       //More Stuff....
Above: diagram 1.0
Please Reply With What I Am Doing Wrong.
-- Clen, Pesso, Tanf, Whatever You Want To Call Me
51st Member Of MindBOARDS! (well, that's that the member's list says)
Re: BricxCC Ultrasonic Sensor Problem
I'm not and NXC expert but I think you will need to initialise the sensor port and tell it what type of sensor you have attached to it...
Indeed. Try adding the following line to the beginning of the program.
SetSensorLowspeed(S4);
pesso
Post by pesso »
Thanks!
It Works Now.
--Clen
