Passing values from one array to another
How do you make an array equal all but the first part of another array? I want to do something like this:
byte ArrayOne[];
byte ArrayTwo[];
...function call that returns, filling ArrayOne with values...
At this point, ArrayOne is the result of a function (undetermined length).
I now want to pass those values to ArrayTwo, but I don't care about the first three bytes of ArrayOne.
I don't want to do the following:
ArrayTwo=ArrayOne;
because it would include the three first "trash" bytes.
I don't want to do this either:
ArrayTwo[0]=ArrayOne[3];
ArrayTwo[1]=ArrayOne[4];
ArrayTwo[2]=ArrayOne[5];
ArrayTwo[3]=ArrayOne[6];
ArrayTwo[4]=ArrayOne[7];
ArrayTwo[5]=ArrayOne[8];
ArrayTwo[6]=ArrayOne[9];
because I don't know how many bytes ArrayOne contains, and I do not want a runtime error.
How should I do it?
Re: Passing values from one array to another
Ok, I think I figured it out. This seems to do what I want:
  i=0;
  ArrayTwoLength=ArrayLen(ArrayOne)-3;
  byte ArrayTwo[ArrayTwoLength];
  repeat(ArrayLen(ArrayOne)-3){
    ArrayTwo[i]=ArrayOne[i+3];
    i++;
From NXCDefs.h:
 * Copy an array subset.
 * Copy a subset of the source array starting at the specified index and
 * containing the specified number of elements into the destination array.
 * \param aout The output array containing the subset.
 * \param asrc The input array from which to copy a subset.
 * \param idx The start index of the array subset.
 * \param len The length of the array subset.
inline void ArraySubset(variant & aout[], variant asrc[], unsigned int idx, unsigned int len);
#define ArraySubset(_aout, _asrc, _idx, _len) asm { arrsubset _aout, _asrc, _idx, _len }
You can pass NA for either the idx or the len. It means 0 for the index. It means "rest of elements" when used with len. You definitely should use this instead of a loop.
Ok, thanks for the advice, it works a lot better your way.
afanofosc wrote:You can pass NA for either the idx or the len. ... You definitely should use this instead of a loop.
why not use a loop (I personally prefer for-loops or while-loops)
I think this is faster and more efficient. Likely, loop uses resources that don't need to be used with the ArraySubset function. Before, I have always only used loops, but only because I didn't know that ArraySubset existed. It seems pretty good to me. I can see how a loop could still be preferred, like if you did some other math or whatever at the same time, and needed an incrementing value in it.
This question actually was addressed to John "a-fan-of-osc (?)" ;)
I was curious about his "You definitely should use this instead of a loop."
Most of the time I do quite different things in my programs instead of copying arrays from one to another, so the runtime performance should be below any measurability ...
ps: what is the local time in Michigan ? Won't you soon need to go to bed ? ;)
pps: in "real C" probably only the pointer to the starting index mem address would be copied :P
Let the firmware do in one line of code what would otherwise (via a for or while loop) take many lines of codes repeated over and over again.
P.S. I am a fan of Orson Scott Card (aka osc)
doc-helmut wrote:This question actually was addressed to John "a-fan-of-osc (?)" ;)
Oh ok, sorry.
The time here in Michigan, is EST, so -5. Berlin is CET, so +1. That means that it is 6 hours earlier here than there (assuming you are in the CET time zone). When you posed that, it registers as exactly 4:00 am, so for you it should read 10:00 am. I am posting this at about 1:55 am here, so about 7:55 am for you. Typically, I go to bed at around 4:30 or 5:00 am, and get up mid afternoon. It is much easier for me to concentrate on what I am doing when the house is quiet.
[very very OT]
@matt:
of course, shame on me - it's earlier in Michigan, not later like I falsely thought... :oops:
@John:
glad to read that there are still other SF fans alive (except me)
I'm a fan of Stanislaw Lem, especially his short stories about Pirx, maybe you already know him?
[/very very OT]
Users browsing this forum: No registered users and 3 guests
