.TRACK Save Problems
dudmaster
Post by dudmaster »
Hello, It's me again. (Have I asked enough? I just want to learn.)
I am having problems with the following code:
void Track(int A[], string Name, int Octave)
int I = 0, Z;
string Doc, T, X = ",";
until (A[I] == 0)
Z = A[I];
T = NumToStr(Z);
StrCat(Doc, Doc, T, X);
I++;
byte handle;
Name = Name + ".track";
DeleteFile(Name);
CreateFile(Name, 300, handle);
int c = 0;
WriteLnString(handle, Doc, c);
CloseFile(handle);
What It's supposed to do:
When used, it saves a .track file with numbers in an array with commas separating them. (So the computer knows what to read)
What It does:
it freezes the NXT, so you have to take the batteries out.
THX,
Dud - 2Labz
2Labz.com, My Website
Re: .TRACK Save Problems
How many elements are in the array? Have you tried the same code with only one or two elements?. What happens if you selectively remove parts of your code? Can you narrow down which part is causing the brick to lock up?
I would not use file extensions longer than 3 characters. The firmware isn't really written to expect filenames with longer extensions.
The StrCat function takes input strings as its parameters and returns the concatenated string as its result. I think you want
Doc = StrCat(Doc, T, X);
In order to pinpoint where the problem is occurring you might want to add some TextOut or NumOut calls so you can tell how far the code executes before the brick locks up.
dudmaster
Post by dudmaster »
Now i'm using .TCK files. This apparently is where it freezes:
Z = A[I];
(Not much, Eh?)
