Issue with starting a post with @
Sometimes I try to start a post like this (for example):
An example post wrote:@Xander, thanks for the tip.
Notice though, it is seemingly not possible to do so. You can't start a post with "@". You can however, start with a space, and then a "@".
If you try to post with just a "@" to begin with, it will not work. I just realized why I sometimes have issues when posting. I could never figure it out. When I would click on "Submit" it would just load a blank page, and it wouldn't post it. Now I know why (or at least one thing that causes this error).
Re: Issue with starting a post with @
Also note that if you attempt to edit the post, it will drop the space automatically, and you must add it again in order to post. Therefore, I suggest using another method, or a different symbol first (like a ~).
haydenstudios
Post by haydenstudios »
Oh my gosh! Thank you SO
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
much Matt! I would never have figured that out myself! That's why I've been unable to make that post for the past 31 hours. Well, better late than never! :D
-Hayden
That's why I have been using the ~ symbol instead. Indeed it was very frustrating until I found the cause.
mattallen37 wrote:Indeed it was very frustrating until I found the cause.
Yeah, I know. :) I'm used to using @ whenever talking about/to someone at StackExchange (it sends a notification in their inbox, so I know I won't get ignored... most of the time).
