[NXC] convert float to int
ricardocrl
Post by ricardocrl »
Is it possible to convert a float number to an integer (rounding the number to floor or ceil), becoming an integer after the operation?
From what I searched and tried, using floor() or ceil() just rounds the number, but the returning value is still a float. I'm trying to pass an integer argument to a function, that had to be calculated as a float before.
The specific example is: I have the expression "angle = 112.5*X". After calculating the angle I want to send the closest integer to PosRegSetAngle(). If I just use floor() or ceil() it doesn't work.
Re: [NXC] convert float to int
This should do the conversion:
#define f2i(x) float2int(x)
int float2int(float x)
    return(x);
if(sin(f2i(1.5)) == sin(1.5))
    TextOut(0, 0, "You should not see this text.", 0);
C-Style casts should go on the wishlist... int(x)
You don't need to explicitly (or "explicitly-implicitly", in this case :? ) convert float to int when passing arguments of a different type (in NXC).
This works fine:
int add(int a, int b)
    return(a + b);
NumOut(0, 0, add(19.84, 23.999)); // Prints 42
ricardocrl
Hm, I just noticed the following behaviours:
float a = 2.5;
int b = 1;
long c = a*b; // c is equal to 2
float a = -2.5;
int b = 1;
long c = a*b; // c is equal to 0
float a = 2.5;
int b = -1;
long c = -2.5; // c is equal to -2
int a = 2.5;
int b = -1;
long c = a*b; // c is equal to -2
float a = 2.5;
float b = -1;
float a = -2.5;
float b = -1;
I hope that can be useful for some debugging.
Understandable. (I would rather c = -3;, though.)
float a = 2.5;
int b = -1;
Wow. :shock:
I think that may solve some bugs in one of my programs...
the mathematically correct way to round a fp value to an integer is this one:
inline long round(float f)
  if (f>=0) return (f + 0.5);
  else  return (f - 0.5);
or, nested:
   return (f>=0? f+0.5 : f-0.5);
HTH!
Technically, the round() method is usually implemented as such:
inline long round(float x)
    return(x + 0.5);
ricardocrl
I'm not that worried about the rounding. The incorrect cast is quite a big issue, I would say.
I worked around the problem in my program right now, but I will certainly get stuck with this later again, trying to understand what is wrong. I hope John had the chance to look at this topic. :-)
muntoo wrote:Technically, the round() method is usually implemented as such:
    return(x + 0.5);
ok, but:
1.) then what's not working for the TO's float conversion?
2.) what's about negative fp values?
ricardocrl wrote: The specific example is: I have the expression "angle = 112.5*X". After calculating the angle I want to send the closest integer to PosRegSetAngle(). If I just use floor() or ceil() it doesn't work.
What do you mean by "it doesn't work"? Do you get a compiler error or the wrong value? Can you post a simple example that shows what is going wrong?
ricardocrl wrote: Hm, I just noticed the following behaviours:
Could you please post the F12 code listing for these snippets. Is it possible that you have an old compiler version? Here's what the latest compiler produces:
    float a = 2.5;
    int b = 1;
//	mov __main_7qG2_a_7qG2_001, __constValf2P5
//	mov __main_7qG2_b_7qG2_001, __constVal1
//	mul __main_7qG2_c_7qG2_001, __main_7qG2_a_7qG2_001, __constVal1
    float a = -2.5;
    int b = 1;
//	mov __main_7qG2_a_7qG2_001, __constValNegf2P5
    float a = 2.5;
    int b = -1;
//	mov __main_7qG2_b_7qG2_001, __constValNeg1
//	mul __main_7qG2_c_7qG2_001, __main_7qG2_a_7qG2_001, __constValNeg1
//	mov __main_7qG2_c_7qG2_001, __constValNegf2P5
    int ai = 2.5;
    int b = -1;
    long c = ai*b; // c is equal to -2
//	mov __main_7qG2_ai_7qG2_001, __constValf2P5
//	mul __main_7qG2_c_7qG2_001, __main_7qG2_ai_7qG2_001, __constValNeg1
    float a = 2.5;
    float bf = -1;
    long c = a*bf; // c is equal to 0
//	mov __main_7qG2_bf_7qG2_001, __constValNeg1
    float a = -2.5;
    float bf = -1;
    long c = a*bf; // c is equal to 2
Notice that I had to rename a couple variables due to a compiler bug I just ran into. NXC does not currently support identically named variables with different types defined at the same nesting level (i.e., you cannot currently have int b and float b both at the same nesting level). As far as I can tell the code generated by the latest version of the compiler is correct and should not produce zero values but I don't have an NXT handy to run the code on to verify that the value of c is non zero in all of these cases. This is with optimization level 2, btw.
Users browsing this forum: Semrush [Bot] and 37 guests
