Change rules
Change rules
Do you think you could make a "No swearing" rule?
Also can we please have animated avatars but with a certain number of frames that cannot be exceeded?
Re: Change rules
I'm no admin here, but here's my two cents worth.
I like the idea of "no swearing", but it really doesn't seem to be a big issue here.
I like little flashing pictures as well, but it gets to be too much of a distraction to have animated avatars. I'd vote no to this, despite the occasional enjoyment I might get.
That's what I think, but I guess Xander or another admin will need to make the final decision (I think it's already been made
Re: Change rules
My only qualification is as a fully certified (and probably certifiable) nit-picker.
So I must ask, do you object to swearing or the use of scatological and other terms related to bodily functions?
As to animated avatars, they rank along with high heels and always-on front fog lights as 'LOOK AT ME' items. Is that the image you wish to convey? Or do you have fog lights on your high heels.......
Re: Change rules
I object to both of those things you said. Maybe not animated avatars, but i don't know. Hopefully we'll get an admin to talk about this.
Re: Change rules
Oh dear, catastrophic sohf!
Re: Change rules
I don't think swearing is a big problem. I've seen a couple posts with words that were offensive to me, but I used the report button and asked the admins to take care of it, and they usually did within 24 hours. I really don't like animated avatars either, but I do use an ad blocker, so it's not a big deal. All I have to do is add the image to the list of things to block and Bingo! problem solved. I used it a lot on NXTasy.
Re: Change rules
Removing avatars
Prerequisites
If you don't use Internet Explorer, you've got your work cut out for ya.
If you use Chrome, download and install AdBlock for Chrome. If you use Firefox, download and install Adblock Plus. If you use Safari, there's AdBlock for Safari.
Code
Add this to your filter list:
Removing only animated avatars
Code
Prerequisites
Code
sourceforge.net##IMG[src^="./download/file.php?avatar="]Code
sourceforge.net##IMG[src^="./download/file.php?avatar=*.gif"]Commit to LEGO Mindstorms Robotics Stack Exchange:
Re: Change rules
No animated avatars, period. That's been a rule since day 0 and I'm not likely to change my mind on that one. All 4 of the founders of this board have a hatred for animated avatars that burns with the heat of a thousand suns.
If you do see swearing happening on these forums, report the post. If it's bad enough I will deal with the offender. Words like "bloody" and "darned" don't count.
Re: Change rules
mightor wrote:Words like "bloody" and "darned" don't count.
Re: Change rules
never knew you fabulous 4 ever could be so emotional :P
but admittedly, I hate them, too ;)
