Power Functions Alternate Power Supply Methods
Are there any alternate ways to supply power to PF motors? The battery box is bulky and kind of difficult to install into small machines such as a bike.
Thanks in advance,
porty6600
Thanks in advance,
porty6600
Re: Power Functions Alternate Power Supply Methods
Sure, a 9v battery would work. There is even a lego 9v battery box.
Thanks. Okay, I picked the one I would like to use, but I wasn't sure if it will power all of the following PF items:
2 M-Motors
1 Set of Lights
1 IR Receiver
1 Control Switch
Thanks, porty6600
2 M-Motors
1 Set of Lights
1 IR Receiver
1 Control Switch
Thanks, porty6600
inxt-generation
Which did you decide?porty6600 wrote:Thanks. Okay, I picked the one I would like to use, but I wasn't sure if it will power all of the following PF items:
2 M-Motors
1 Set of Lights
1 IR Receiver
1 Control Switch
Thanks, porty6600
A.K.A. NeXT-Generation.
Woops! I meant to post the link! Here it is: http://www.bricklink.com/catalogItem.asp?S=5391-1
Keep in mind that a 9V block battery usually has between 150 and 250 mAh versus about 1500-2500mAh for 6xAA. So your motors won't run for as long as a normal power supply.
That does not sound good! What exactly does that mean? The battery life?mightor wrote:Keep in mind that a 9V block battery usually has between 150 and 250 mAh versus about 1500-2500mAh for 6xAA. So your motors won't run for as long as a normal power supply.
Well, think of a mAh (milliamp Hour) of a unit of power capacity. The more units you have, the longer you can provide power. OK, now say you are using a motor that draws 150mA when driving a small motor cycle. If your battery has a capacity of 300mAh, it will theoretically power your motor for 300 mAh/ 150mA == 2 hours. So naturally, if you are using 6x 2100 mAh 1.5V AA batteries, your motor will last 2100 mAh/150mA == 14 hours.
This is theoretical, of course. If you are going the route of the 9V battery block, which is nice and compact and light, I would recommend using rechargeable batteries, or you'll end up spending a fortune on these.
Regards,
Xander
Regards,
Xander
Thanks, I think I understand now. Would you still go this route? And I didn't see an answer on my power supply post above your first one.mightor wrote:Well, think of a mAh (milliamp Hour) of a unit of power capacity. The more units you have, the longer you can provide power. OK, now say you are using a motor that draws 150mA when driving a small motor cycle. If your battery has a capacity of 300mAh, it will theoretically power your motor for 300 mAh/ 150mA == 2 hours. So naturally, if you are using 6x 2100 mAh 1.5V AA batteries, your motor will last 2100 mAh/150mA == 14 hours.
Regards,
Xander
porty6600
inxt-generation
You should be fine with that. The recommended rating per battery box by LEGO is: 4 PF M-Motors, or 2 PF XL-Motors. Those ratings take into account powering the IR-Receiver. You should be fine with 2 m-motors and a light. The control switch shouldn't make a difference. Just be aware, as Xander said, that a 9-volt box battery won't last as long as 6 double or triple a.porty6600 wrote:Thanks, I think I understand now. Would you still go this route? And I didn't see an answer on my power supply post above your first one.mightor wrote:Well, think of a mAh (milliamp Hour) of a unit of power capacity. The more units you have, the longer you can provide power. OK, now say you are using a motor that draws 150mA when driving a small motor cycle. If your battery has a capacity of 300mAh, it will theoretically power your motor for 300 mAh/ 150mA == 2 hours. So naturally, if you are using 6x 2100 mAh 1.5V AA batteries, your motor will last 2100 mAh/150mA == 14 hours.
Regards,
Xander
porty6600
